What does the calibration file means?
Get your Calibration File
The ZED and the ZED mini are using stereo vision to estimate the depth. This technology requires to know precisely the position of the right optic in relation to the left one and their characteristics.
We are measuring this in the factory and exporting a calibration file that is automatically downloaded by the SDK or any application.
Calibrations files are stored here and named from the serial number of your camera:
  • On Windows: C:\ProgramData\Stereolabs\settings
  • On Linux: /usr/local/zed/settings/
  • On Windows (SDK ≤ 2.2.0):C:\Users\YOUR_USER_NAME\AppData\Roaming\Stereolabs\settings\
You can also download it manually by following the instructions here: calib.stereolabs.com
Sensors Parameters
The ZED calibration files contain intrinsic parameters for both left/right sensors at each resolution. This corresponds to the following input:
[LEFT_CAM_HD]
fx=700.819
fy=700.819
cx=665.465
cy=371.953
k1=-0.174318
k2=0.0261121
  • fx and fy corresponds to the focal measured in pixels.
  • cx and cy represent the coordinates of the optical center in pixels.
  • k1 and k2 are distortion parameters.
These data are matching the pinhole camera model.
Stereo Parameters
The stereo parameters, also called extrinsic parameters, are representing the relation between the left and right sensors. More precisely, the position of the right sensor from the left sensor referential. With the center of rotation being the right sensor itself.
[STEREO]
Baseline=120
CV_2K=0.00958521
CV_FHD=0.00958521
CV_HD=0.00958521
CV_VGA=0.00958521
RX_2K=0.00497864
RX_FHD=0.00497864
RX_HD=0.00497864
RX_VGA=0.00497864
RZ_2K=-0.00185401
RZ_FHD=-0.00185401
RZ_HD=-0.00185401
RZ_VGA=-0.00185401
  • Baseline is the distance between the optics in mm (120mm for the ZED, 63mm for the ZED Mini)
  • CV_*** are the measures of the convergence of the optics. It could have been named RY_***.
  • RX_*** and RZ_*** are the other rotation axis describing the transformation between the two sensors. Rotations are represented in the Rodrigues notation.
