Setting up your Stereo Rig with two ZED X One cameras
The monocular cameras of the ZED X One family (ZED X One GS, ZED X One S, ZED X One 4K, and ZED X One Core) allow the creation of configurable stereo rigs with custom baselines, the distance between the optical centers of the two cameras.
Dual Camera Mount for ZED X One
Lens options
Lens
Focal length
Aperture
Field of view (H x V x D)
Available on
Wide
2.2 mm
f/2.2
110° x 80° x 120°
ZED X One GS, ZED X One S, ZED X One Core
Narrow
4.6 mm
f/2.0
73° x 45° x 87°
Fisheye
1.38 mm
f/2.0
204° x 137° x 218°
Wide (4K)
3.1 mm
f/2.0
110° x 72° x 119°
ZED X One 4K
The wide, narrow, and 4K lenses follow a pinhole (rectilinear) projection model. The fisheye lens follows a fisheye projection model (f-theta), with a field of view wider than 180°: to compute depth, the fisheye images are rectified to pinhole images with a smaller field of view. For more details, see What is the camera focal length and field of view?
How to calculate the baseline
The value of the baseline depends on the final requirements and on the optics of the two cameras.
In the following scheme, the baseline is identified by B, the minimum depth range is h, and α is the field of view of the cameras for the rectified images.
Stereo rig field of view, baseline, and minimum depth
For a fixed minimum depth value h, you can calculate the required baseline B as:
B = 2 * h * tan(α/2)
Vice versa, if you fix the baseline B, the corresponding minimum depth value h is:
h = B / (2 * tan(α/2))
To obtain a minimum depth that allows a usable depth map, apply a factor of 6 to h. This guarantees that the fields of view of the two cameras have a large enough overlapping area:
h' = 6 * h ; B' = B / 6
The maximum depth (in meters) can be calculated with the formula:
max_depth = (B / 2) * (F / sens_w) * res_W
where:
  • B is the baseline in meters;
  • F is the focal length of the lens in meters (2.2 mm for the wide lens and 4.6 mm for the narrow lens of the ZED X One GS, ZED X One S, and ZED X One Core; 3.1 mm for the ZED X One 4K);
  • sens_w is the width of the CMOS sensor in meters (5.8 mm for the global shutter sensor, 7.7 mm for the 4K sensor);
  • res_W is the image width in pixels (you can use 1280 as a good approximation).
For the fisheye lens, use α and the equivalent focal length of the rectified images instead of the nominal values: with a rectified horizontal field of view of 120°, α = 120° and F / sens_w = 1 / (2 * tan(60°)) ≈ 0.29.
How to choose the right sensor?
The global shutter sensor (ZED X One GS, ZED X One S, ZED X One Core) is best for fast-moving objects, or a fast-moving camera, and for applications that require accurate motion reproduction.
The rolling shutter 4K sensor (ZED X One 4K) is best for low-light environments and for high-resolution HDR images.
How to choose the lens?
The field of view of the lenses has a direct impact on the system performance, so choose it according to the requirements of your application:
  • Narrow lenses provide greater detail and are well suited for long-range detection.
  • Wide lenses are best for applications requiring broader coverage.
  • Fisheye lenses (ZED X One S and ZED X One Core) provide maximum field awareness, with a field of view of more than 180°, for short-range perception and wide-area monitoring. The large field of view comes with strong image distortion and lower angular resolution, which reduce the detail and the depth accuracy at long range compared to the wide and narrow lenses.
Narrow and wide FOV comparison
How to choose the baseline?
The baseline of the stereo system depends on the required depth perception. A larger baseline improves the depth resolution, but increases the minimum distance for accurate depth estimation. The following tables provide an estimate of the depth accuracy at different distances, depending on the baseline and the lens option.
How to read the tables:
  • plain values are in the recommended zone (depth error below 5% of the distance);
  • italic values are available, but the depth error is 5% or more of the distance;
  • "–" means that depth is not available for that combination of baseline and distance.
ZED X One GS, ZED X One S, and ZED X One Core with wide lens (2.2 mm)
Baseline \ Distance
10cm
30cm
50cm
75cm
1m
1.5m
2m
3m
4m
5m
7m
10m
20m
25m
50m
100m
200m
300m
3cm
<1mm
1mm
4mm
8mm
15mm
34mm
6cm
14cm
24cm
38cm
74cm
7cm
1mm
2mm
4mm
6mm
14mm
3cm
6cm
10cm
16cm
32cm
64cm
15cm
1mm
2mm
3mm
7mm
1cm
3cm
5cm
8cm
15cm
30cm
1.20m
1.88m
25cm
1mm
2mm
4mm
1cm
2cm
3cm
5cm
9cm
18cm
72cm
1.13m
4.51m
50cm
2mm
<1cm
1cm
1cm
2cm
4cm
9cm
36cm
56cm
2.25m
9.02m
75cm
<1cm
1cm
1cm
2cm
3cm
6cm
24cm
38cm
1.50m
6.01m
1m
<1cm
1cm
1cm
2cm
5cm
18cm
28cm
1.13m
4.50m
18.04m
1.5m
<1cm
1cm
1cm
3cm
12cm
19cm
75cm
3.00m
12.01m
27.05m
2m
1cm
1cm
2cm
9cm
14cm
56cm
2.25m
9.00m
20.27m
ZED X One GS, ZED X One S, and ZED X One Core with narrow lens (4.6 mm)
Baseline \ Distance
10cm
30cm
50cm
75cm
1m
1.5m
2m
3m
4m
5m
7m
10m
20m
25m
50m
100m
200m
300m
3cm
1mm
2mm
5mm
9mm
20mm
3cm
8cm
14cm
22cm
43cm
87cm
7cm
<1mm
1mm
2mm
4mm
8mm
1cm
3cm
6cm
9cm
18cm
37cm
1.49m
2.33m
15cm
1mm
2mm
4mm
1cm
2cm
3cm
4cm
9cm
17cm
69cm
1.09m
4.35m
25cm
1mm
2mm
<1cm
1cm
2cm
3cm
5cm
10cm
42cm
65cm
2.61m
10.45m
50cm
<1cm
<1cm
1cm
1cm
3cm
5cm
21cm
33cm
1.30m
5.21m
20.90m
75cm
<1cm
1cm
1cm
2cm
3cm
14cm
22cm
87cm
3.47m
13.91m
31.35m
1m
<1cm
1cm
1cm
3cm
10cm
16cm
65cm
2.61m
10.43m
23.48m
1.5m
1cm
2cm
7cm
11cm
43cm
1.74m
6.95m
15.64m
2m
1cm
5cm
8cm
33cm
1.30m
5.21m
11.73m
ZED X One S and ZED X One Core with fisheye lens (1.38 mm), rectified to a 120° horizontal field of view
Baseline \ Distance
10cm
30cm
50cm
75cm
1m
1.5m
2m
3m
4m
5m
7m
10m
20m
25m
50m
100m
200m
300m
3cm
<1mm
2mm
5mm
11mm
20mm
45mm
8cm
18cm
32cm
50cm
7cm
1mm
2mm
5mm
9mm
19mm
3cm
8cm
14cm
21cm
42cm
86cm
15cm
<1mm
1mm
2mm
4mm
9mm
2cm
4cm
6cm
10cm
20cm
40cm
1.60m
2.50m
25cm
1mm
1mm
2mm
5mm
1cm
2cm
4cm
6cm
12cm
24cm
96cm
1.50m
50cm
1mm
3mm
<1cm
1cm
2cm
3cm
6cm
12cm
48cm
75cm
3.00m
75cm
2mm
<1cm
1cm
1cm
2cm
4cm
8cm
32cm
50cm
2.00m
7.99m
1m
<1cm
1cm
1cm
1cm
3cm
6cm
24cm
37cm
1.50m
5.99m
1.5m
<1cm
1cm
1cm
2cm
4cm
16cm
25cm
1.00m
3.99m
15.97m
2m
<1cm
1cm
1cm
3cm
12cm
19cm
75cm
3.00m
11.98m
26.96m
The fisheye values are a theoretical estimate for images rectified to a 120° horizontal field of view; a wider rectified field of view reduces the minimum depth, but also the depth accuracy and the maximum range.
ZED X One 4K with wide lens (3.1 mm)
Baseline \ Distance
10cm
30cm
50cm
75cm
1m
1.5m
2m
3m
4m
5m
7m
10m
20m
25m
50m
100m
200m
300m
3cm
<1mm
1mm
4mm
8mm
14mm
32mm
6cm
13cm
23cm
36cm
70cm
7cm
1mm
2mm
3mm
6mm
14mm
2cm
5cm
10cm
15cm
30cm
61cm
15cm
1mm
2mm
3mm
6mm
1cm
3cm
5cm
7cm
14cm
28cm
1.14m
1.78m
25cm
1mm
2mm
4mm
1cm
2cm
3cm
4cm
8cm
17cm
68cm
1.07m
4.28m
50cm
2mm
<1cm
1cm
1cm
2cm
4cm
9cm
34cm
53cm
2.14m
8.55m
75cm
<1cm
1cm
1cm
1cm
3cm
6cm
23cm
36cm
1.42m
5.70m
22.84m
1m
<1cm
1cm
1cm
2cm
4cm
17cm
27cm
1.07m
4.27m
17.11m
38.58m
1.5m
<1cm
1cm
1cm
3cm
11cm
18cm
71cm
2.85m
11.39m
25.66m
2m
1cm
1cm
2cm
9cm
13cm
53cm
2.13m
8.54m
19.23m
In the StereoLabs store, you can find the Dual Camera Mount for ZED X One, an aluminum bar to create precise stereo rigs with two ZED X One GS or ZED X One 4K cameras, with a customizable baseline from 52 mm to 222 mm. For the ZED X One S, see the Camera Mount for ZED X One S.
Dual Camera Mount for ZED X One, top viewDual Camera Mount for ZED X One
Calibration
A custom stereo rig must be calibrated before it can be used with the ZED SDK. See the Dual Camera Stereo Vision documentation for the ZED X One GS, S, and 4K, and the ZED X One Core Dual Camera Stereo Vision documentation for the ZED X One Core.
